Schuberth Concept Face Shield Fix
B
bmwmick
Has anyone noticed the anti-fog coating peeling off the inside of their face shield?
My almost new helmet had this problem.
I found an easy way to remove the coating if it has started to peel. Remove the shield, take it outside and direct a high pressure water spray against the inside of the shield at about a 45 degree angle. It will peel right off in small sections.
My K11LT windscreen did this same thing aobut 7 years ago and I used the same method to remove it. No hard scrubbing and NO scratches.
Mick:clap
I hope Schuberth has replaced your shield N/C. I have a Schuberth and am very interested in how they handled your shield complaint
I called Intersports Fashions in CA and they kinda blew me off. Told me to find a local dealer who should be able to handle the problem.
Mick
I've had to replace a couple shields due to me being stupid and as you probably know they are not cheap. Please keep us informed . I'd like to see how this plays out with the mfr.
