Results 1 to 11 of 11
Thread: 12gs Windscreen And Electrics Question
    downhillhunter
    If I get a 1200, I need to put a taller windcreen on it.
    I now have a taller Aeroflow on my 1100, with lower fairing and it works great.
    But they're not inexpensive!
    How tall is the Adventure screen for the GS? And does anyone know what they cost?
    Second Question:
    I've also heard that the electronics on a 12GS are different (from my 1100) and that maybe you just can't add lights and other power accesories, like I did on my 1100.
    What's the scoop on that?
    Thanks,
    Downhill Hunter
    Spring Lake NJ, USA
    Downhill,
    Can't answer your screen question - but I'm sure there are people here who can (moved your thread to the correct section - Hexheads..)
    Your other question - electronics... well, yes and no.
    You can't just hack into the wiring harness on the new bikes and hang electronics off it. CAN-Bus isn't designed that way. Think of a central distribution system much like your home - with centrally located circuit control with automatic circuit breakers - that turn things off if they see a short or excess current draw - and then turn them back on when the problem is gone.. This means - powering your axillary lights off say the existing light circuit will turn both of them off - the current draw is excessive for the wiring so the CAN-Bus controller shuts it down to protect the wiring.
    What people have done to get around this - is work off a centrally located axillary fuse box - powered directly off the battery.
    If they need a circuit that is switched with the ignition on the bike - it can be provided with a relay taking it's switched power (coil side) off something like the accessory socket, or with a "CAN-Bus Helper" http://www.touratech-usa.com/shop/sh...FB72002B792E46 which provides fused, switched power for the devices you choose to connect.
    In the case of the auxillary lights - powering them through a switched relay - drawing power from the battery for the switched side of the relay, and drawing coil power from the light circuit WILL work, but may over-ride the bulb-monitor feature of the CAN-Bus controller (where it will warn you if the bulb is out..)
    It's all doable - and the increased reliability and simplicity of the CAN-Bus system makes it really a desirable way to go.. there are more and more "CAN-Bus" compatible devices being released since it's obvious BMW isn't going back to the old way of doing things - and manufacturers want to sell their products to us.
    Hope that answers your question.
    GSMoto31 mtfrench's Avatar
    Apr 2006
    Miami Beach, FL and Maggie Valley, NC
    12GS windscreen
    After riding 20K in 2 years with the stock windscreen on my GS I decided to give the Cee Baily's windscreen a shot. I saw one at the RA rally in Asheville and picked it up for $150 with no tax or shipping charges. It is 4 inches taller than the stock and seems to have a little more protection on the sides as well. I am 6' tall and it fits me perfect. Much less wind buffeting and, most important for me, no more irritating vibration like was present when I accelerated in first gear with the stock shield.
    I can't say how this compares to other aftermarket shields for the GS, but it works great for me.
    2009 R1200R (Commuting)
    2008 R1200GSA (Touring)
    2009 R1200GS (Mountains)
    downhillhunter
    Thanks, Guys!
    I appreciate it.
    Downhill Hunter
    Focused kbasa's Avatar
    If you want to put an Adventure screen on, you'll need to buy both the bracket and the shield, which cost almost $600!
    Dave Swider
    Marin County, CA
    downhillhunter
    Thanks, Kbasa!
    $600!! You can get a tall aeroflow, half fairing and lower air scoops for about
    $656!
    That's the kind of info I need. I think I'll wait until I'm at the Rally in West Bend and then I'll look around a little bit.
    Hopefully I'll have a 12GS by then!
    Downhill Hunter
    pgods
    Cee Bailey windshield
    FYI... I have the same shield as mtfrench ...for sale. 4" higher and 2" wider as he described, tinted ice blue, in pristine condition (looks new). $140 plus S&H
    Can email pics. I just listed it on IBMWR today 6/24
    MRMAICO
    A&S BMW sells the Adventure screen kit with all the parts needed for just under $500. http://www.ascycles.com/detail.aspx?ID=43745
    Or Cee Bailey sells a replica of the Adv screen and winglets for between $300 and $375 depending on the size you want.
    http://www.ceebaileys.com/bmw/1200gsepws.html
    Or you can do like I, and alot of other people, have done and get a Givi screen for about $150 and the Adv winglets from BMW for about $50. Works great and it cured all my noise/buffeting issues.
    http://www.twistedthrottle.com/trade...view/1915/289/
    Barry
    Spring Lake NJ, USA
    Quote Originally Posted by pgods View Post
    This really does NOT belong here - there is a Flea Market section just for this purpose.. please keep for/sale/wanted to that section.
    Thanks for your cooperation.
    Has the GS-Lust The_Veg's Avatar
    Sep 2003
    Atlanta 'burbs
    Barry, how tall are you?
    2012 R1200GS
    "If you can't fix it with a hammer, it's electrical." -somebody's dad
    MRMAICO
    Quote Originally Posted by The_Veg View Post
    Hi Veg! 5' 10"
