Results 1 to 6 of 6
Thread: Vaccum in crankcase?
    What's that noise...? basketcase's Avatar
    Alabama
    This afternoon I removed the oil filler cap to add a snort to the K, and noticed a vaccum in the crankcase.
    Granted, I parked it hot, and our weather has turned winter-time cold since I last rode.
    I can see where it would be reasonable ... the engine is hot, gases are expanded, and then when it cools, the pressure drops, creating a vaccum inside. But I don't recall ever having such a vaccum in the K100 or the K75.
    Is this (vaccum) a normal occurence, or do I need to be nosing around for some type of "issue?"
    Thanks in advance,
    RM
    '98 BMW Z3 Roadster, '00 R1100RT
    If you insist on exercising a right to burn our flag, first be so kind as to wrap yourself in it and then douse yourself with gasoline just before you strike the match.
    Registered User 41107's Avatar
    Jul 2003
    mundelein il. usa
    Thumbs up vac. in crankcase
    It's a wonderful thing to have such a tied engine.I would be happy about it.How many miles are on the engine?
    Alabama
    Mileage is ...
    29,159 ... when I parked it just a few minutes ago.
    Has the GS-Lust The_Veg's Avatar
    Sep 2003
    Atlanta 'burbs
    This makes me wonder if your crankcase breather hose is clogged. Then again I have no experience with these newer models (which based on the mileage I presume you have). I don't know if they have any type of valve, but the early model I had did not, which means that if my old K had a vacuum condition in the case it would equalise through that tube since it's connected to the intake plenum and the pressure flow in from the outside would only be slightly restriced, but certainly not blocked.
    Of course you can also look at it this way- if it's holding that vacuum fairly well, then that vacuum isn't finding a place to suck in things that don't belong inside. But do make sure your crankcase venting is functioning properly.
    2012 R1200GS
    "If you can't fix it with a hammer, it's electrical." -somebody's dad
    Alabama
    Hmm.
    Well, I do know a K will not run properly with the filler cap off the crankcase.
    - I don't have any leaks.
    - It is not using any more oil than usual (about a half-quart per thousand miles).
    Maybe I'm just paranoid.
    Which reminds me, I forgot my meds this morning.
    Bye.
    Sep 2003
    Atlanta 'burbs
    I must've too when I looked again just now and realised how much stuff I mis-spelled (fixed now).
    2012 R1200GS
