J
JWHITE518
Connected to two AP-1's I have wiring for the following devices:
What's the best way to make a wire longer?
How do you deal with connecting wires of different gauges?
What's the best wire loom and where do you get it?
How do you label your wires? (or do you eschew labeling the pairs and just use a master diagram?)
When a device comes with an inline fuse, but you're already connecting it to a fuse block, do you eliminate the inline fuse?
Do you tin the bare end of a wire that you're screwing into an aux fuse block?
Who's got photos? I know some of you BMW folks are really good at this. I'm really hoping you can share some expertise. Thanks.
- Motolights with relay
- PIAA halogen lights with relay
- GPS
- V1
- Star-Traxx
- Hyperlite brake flashers
- Mix-It
- Heat Troller
- and probably some I've forgotten.
