Results 1 to 5 of 5
Thread: DeLorme vs Microsoft Streets
    P Monk
    May 2005
    Port Neches, Texas
    Good article by Bradford Benn.
    I have been considering a new map program since my MS is a 2000 year.
    Does the DeLorme show more secondary roads at a higher range than the Microsoft?
    My complaint with MS is that you have to zoom down to 70 mile range to see the secondary roads. Farm to Market, Ranch Roads etc.
    Does the DeLorme allow you to reroute by clicking on route and dragging to another point like the Microsoft?
    State of Confusion
    I will check this out as I do not remember at the moment.... give me a day or two. Something about traveling for work at the moment.
    I am glad you enjoyed the article.
    -=Brad
    State of Confusion
    Delorme does not allow one to click and drag the route. One would need to right click and add a via.
    In terms of resolution... a picture is worth a thousand words.
    -=Brad
    Registered User easy's Avatar
    Feb 2005
    Texas Hill Country
    Thanks for the information. You've probably saved a number of people from getting lost.
    Like you say, a picture is indeed worth a thousand words.
    Easy
    Ritalin Poster Boy rob nye's Avatar
    Bristol, Rhode Island
    Hey now,
    That was a great article.
    If you ask Iron Butt Riders they are in agreement with Brad on most if not all of his observations.
    Having said this if you are a navigational geek and have the time to really learn software *and* you may use a laptop connected to a GPS while moving the Delorme product is far superior.
    For me Delorme is better because I can insert Vias (instead of dragging a route). I also like tagging waypoints as draw objects and then exporting them to the GPS and I rarely if ever build a route in put it in the GPS unless I use the Garmin software to build the route. The advantage is a via is not handled as a waypoint, in Streets and Trips the only way to add a road to your route is to drag it or tag it as a waypoint. I think that if you drag a road and then add a waypoint when it recalculates it reverts back to the previous route.
    In the 2005 Iron Butt Rally I had a tablet PC connected to a GPS running Delorme. I would also select my next waypoint as a destination in the GPS. I found after a few days that the routing from the GARMIN 2610 was superior to what DeLorme was generating on the go.
    In my opinion MS is better for planning and Delorme is better for navigating.
    Best,
    Rob Nye
