Results 1 to 7 of 7
Thread: M/C Boots
    Registered User bmwterrien's Avatar
    W.MA
    M/C Boots
    Greetings-
    I would like to purchase a pair of M/C boots with REAR Zippers. Since I cannot move my right ankle, it is the only way I can get into a boot .
    I have tried Bates Fast Line Boots but they won't work for me.
    Any suggestions?
    TIA
    Steve
    Steve Terrien
    BMWMOA #18114
    BMWMOV
    State of Confusion
    Aerostich Combat Boots?
    Not truly rear opening, but have you looked at the Aerostich Combat Boot? It looks like it would open pretty wide and would be a lateral twist with the knee.
    HTHhttp://www.aerostich.com/isroot/ride...html?400li.jpg
    -=Brad
    R1100R "Traveler" DesertRider's Avatar
    Arizona, USA
    Steve,
    Many motocross boots will open quite wide as well. When I had an ankle injury a couple of years ago I was still able to get into motocross boots. (I wasn't able to ride, but found them quite supportive for walking around.)
    Motocross boots feel as stiff as a plaster cast when new, but once broken in they can be quite supple and comfortable and can make very capable (and very protective) road boots. That's particularly true of the "lighter" motocross boots, i.e., those with more leather and less of the rigid plastic panels. I have a pair of AlpineStars M6 boots that I just bought specifically for (mostly) road-riding -- still wearing them around the house to break them in.
    Anyway, might be worth a little shopping trip to see what's available, see if they might work for you.
    DesertRider in sunny Arizona, USA
    Has the GS-Lust The_Veg's Avatar
    Sep 2003
    Atlanta 'burbs
    Thumbs up
    If all else fails you could probably get a shoe-repair shop to modify existing boots and sew in a rear zipper for you.
    2012 R1200GS
    "If you can't fix it with a hammer, it's electrical." -somebody's dad
    Gary99
    Someone above mentioned the Combat Tourer, I use them and they are pretty wide open down to the ankle, where they require a push. You can get them on from various angles, but don't know if it would be enough for you. Very comfortable boot, for one that is almost knee high.
    WesPeterson
    try this - not sure if "special calf-adjustment" means anything for you but maybe...
    http://www.glfacc.demon.co.uk/800x60...tona_frame.htm
    Club President
    Oct 2003
    New York City
    I was looking at all the pretty stuff in a brand new Aprilla/Mot0Guzzi shop here in Manhattan last Saturday.
    They feature Dainese gear and there was a Dainese boot with dual zippers on either side of the back so the back of the boot would fold down. It did not fold down completely but the heel piece left should not create more of a need to bend the ankle than for a regular lace up oxford type shoe.
    I looked a bit on the net and couldn't find anything that showed the dual zipper thing I saw - but I did see it
    Allen Clarkson
    CitiBeemers, NYC
    K12RS '02 IBM
