Results 1 to 5 of 5
Thread: Water pump
    eric2
    Water pump
    I'm rebuilding my water pump and looking at the leak. Where is the weep hole for it? It doesn't look like it's leaking there
    IMWTK!
    Blocking the slow lane
    Edwardsville, IL
    The weep hole is in the oil pan, at the very front edge. It looks like you've just had a nasty cover leak....probably didn't need to take the whole thing apart.
    Jon Diaz
    BMW K75/K12GT
    BMWMOA Ambassador
    eric2
    oh well........
    Thx Jon, like your lt there's an intermediate
    oil line housing that may be covering the weep hole
    so I'll look closer to see. Nothing in the cover
    looked like a source though.....
    Edwardsville, IL
    Re: oh well........
    Ah! This was on a K12RS? Wasn't there a recall on early models to repair something in the water pump area?
    Jon Diaz
    BMW K75/K12GT
    BMWMOA Ambassador
    eric2
    'tis the water pump
    In fact it is the water pump, the weep hole protrusion
    is just right of the sending unit. Duh,
    You can see the trail of water line up as it dribbled
    down from there
    More pics and such when I finish it and the timing
    chain cover re-seal . FWIW, doing both makes
    sense due to the sensor wires running through
    both pieces. I'll be using Yamabond for the sealer.
    Cam chain tensioner is different than the early
    K engines as well.
