Results 1 to 15 of 16
Thread: Eagle Eye lights -- product review (long)
    R1100R "Traveler" DesertRider's Avatar
    Arizona, USA
    Serious Long-Range Lights at a Remarkable Price
    I've recently been shopping for some long-range lights for my R1100R. I wanted something to supplant the standard headlight (with a PIAA Xtreme White bulb, which helps a lot), which provides good light for near and midddle distance, and Motolights, which are good for close/wide lighting. What I was looking for was some lights to provide some real long-range punch for high-speed night riding, yet with a beam wide enough to light up the edges of the road several hundred yards out. I want to see not only obstacles long before I encounter them, but also the shiny deer eyes lurking in the bushes.
    I'd recently purchased some Hella 500 driving lights for my pickup truck and found that they work well, are quite light, and provide a tight pencil beam out to a good distance. However, for the bike I wanted something with more of a flat-oval pattern (the Hellas have a tight round spot beam), and something a bit smaller. The Hella 500s are as large as the headlight on my 1100R, which would not only look awkward, but posed a mounting problem -- on a motorcycle there's no easy way to mount a pair of lights that big.
    The common thing to mount on a bike like this are PIAA 500-series lights or smaller, but after looking at several PIAA models I was disappointed. They seemed well made, but I thought they were insanely overpriced. Having some background in optics and electronics, I could see that driving lights are, at heart, very simple things, and I simply could not see $150 or more of value in a simple metal shell, reflector, a simple clear lens, and $6 bulb. I understand that to some degree one pays for the name, but in this case it seemed excessive. I was also disappointed with some of the features of the PIAA, such as the needlessly obstructive grille guards, which in the case of the 500 series blocked about 40% of the light generated by the bulb. To me that seemed an inexcusable waste, much of it for the sake of having a huge block-letter PIAA advertising logo across the front of the light.
    Reaching into my old days of off-roading and 4-wheeling, I looked at some of the lights offered for off-road racing, such as KC Daylighters and similar. These are the muscle-bound commandos of driving lights, super-powerful beams in steel housings with rubber vibration isolators. If they can survive the pounding of Baja racing, they can survive anything. They're not cheap either (though less expensive than PIAAs), but they're typically large to very large (some are more than 9 inches across and 150 watts), generally too big and heavy for a motorcycle. However, it looked like the smallest (5-inch and 6-inch) sizes might work on my 1100R. From past experience I know that Daylighters, being essentially adapted aircraft landing lights, throw a very powerful long-range beam, easily the equal or better of any common motorcycle lights I've ever seen.
    It was while shopping for KC Daylighters that I came across Eagle Eye lights. According to a fellow in the business, Eagle Eye lights are identical to KC Daylighters in every way (this fellow said they are the *same* lights sold as Daylighters), but sold without the KC Daylighters name they are much cheaper. Shopping around I was able to find a pair of 5-inch, 100-watt Eagle Eye driving lights for just over $20 each. That seemed too good to be true, but comparing them side by side with the 5-inch Daylighters I simply could not find any difference -- same deep-chromed steel housing, same rubber lens/reflector mount, same stainless-steel retaining rings, same H3 bulb, everything the same. I cannot vouch that they are indeed the same light, but comparing them side by side I can easily believe it.
    So for less than $50 (!!!) I found myself the owner of a pair of 5-inch, 100-watt, bright-chromed Eagle Eyes. (Stainless steel and black powdercoat are also available.) For that price there was no electrical hookup kit included, but it did include soft covers and a length of flexible stainless-steel conduit for each light for routing the light wiring (see photos).
    Side view of the Eagle Eye mountings. Note the spiral stainless-steel conduit for the wiring -- these came with the lights.
    A quick test of the beam pattern showed it to be ideal -- a sharply-defined wide oval, roughtly 2X wide as high. Aimed with some overlap, the two lights provide a very, very long central beam, yet still illuminates the sides of the road beyond the distance where the human eye could make out shapes. I'm even thinking of swapping the 100-watt bulbs for 55-watt bulbs, as 200 watts of this kind of beam may be overkill for my purposes.
    I mounted the lights upside down below the turn signals using simple aluminum brackets (see photos). The brackets are very simple 2" x 2" aluminum angle, with holes drilled for the turn signal stalk, headlight side screws, and the Eagle Eye mounting bolt. I did modify the vibration dampeners on the mounting brackets of the lights so that they could be mounted in a half-inch hole rather than the > 1-inch hold required for the full rubber damper. (The mod required only one cut with a pocket knife to remove a rubber damper disc.)
    Mounting the lights upside down did require two minor mods: I removed the lens/reflector assemblies from their rubber mounting collars and turned them 180 degrees (so that the "TOP" mark was on top), and I drilled tiny holes in the bottom of the housings to allow any water inside to run out. The lights look to be quite weatherproof, but from past experience I've learned to make sure that no water can pool anywhere near anything electrical, even if just from condensation.
    The result is what you see in the photos. The lights are big enough to seem a bit prominent, but not really out of proportion with the bike or the main headlight. I'm not totally happy with the appearance of the mounting bolts poking above the mounting brackets, and I'm still mulling what to do with that (perhaps some nice chrome caps?). Overall I'm very happy with them so far; they provide a dazzling blowtorch of light beyond the limits of practical need, and as a side benefit give the bike a distinctive, purposeful look. The only drawback is that they are *so* bright that one has to be careful about turning them on -- anyone within a half mile will curse you for them, within a quarter mile will be nearly blinded by them, and any much closer that nat will probably get a suntan and maybe some curled paint.
    Overall a purposeful and good-looking package on the 1100R -- the Eagle Eyes are large without being overwhelming. Compare with the small Motolights lower down on the fork (brake bolt mount).
    Only time will tell how these lights work out in the long run, but in the meantime I thought I'd pass along what could be an excellent choice in serious long-range lighting. Similar 6-inch and 8-inch models are available with bulbs up to 150 watts, in case you want to be able to signal other planets, all at remarkably low prices. Eagle Eyes are not much advertised (which I suppose is what allows the very low prices), but are widely available from many sources -- a quick search on Google turned up many retailers. Certainly worth considering if you're looking for a beefy, durable light with the ultimate in long reach and beam pattern.
    DesertRider in sunny Arizona, USA
    Focused kbasa's Avatar
    Totally cool! Did you fabricate the mounts?
    Dave Swider
    Marin County, CA
    Arizona, USA
    "Fabricate" seems a $5 word for a $2 effort, but yeah, I made them. Got some 2" x 2" x 1/8" aluminum angle at Ace Hardware, sawed off two 4" lengths, drilled the holes, rounded the corners. That's about it. Very simple stuff; you could do it with a drill and a hacksaw.
    State of Confusion
    Thanks for the info
    Think they might be a little too big to mount cleanly on the RT, but it is good to know the options.
    -=Brad
    I was looking at the mounts and the bolt stems and wondered if you had enough room to mount the lights aft of the turn signals? That would make it look nice and tidy.
    Or would they foul the fork legs?
    Also, you could probably shorten the bolts and stick an acorn nut on top to make it look neater.
    I'm really intrigued by these lights.
    Dave Swider
    Marin County, CA
    State of Confusion
    Bolt from top down?
    Does the light come with the bolt already installed? Maybe one could get away with tapping the light instead... Just thinking
    -=Brad
    Arizona, USA
    No, they won't fit behind the turn signals. The light housings are fairly deep, as you can see, and would not come close to clearing the fork legs.
    That's what I was thinking too. But I think I'll leave them that way for now and give it some more thought. I keep thinking that the bolts would be a good place to mount the running lights that BMW left out of the turn signals, but haven't figured out how do that neatly either. A bit more time and a bit more thinking may yield a better idea. The brackets you see here were about the 5th design I came up with; with each iteration they got simpler and smaller. Maybe the same stepwise progression will yield the best solution for what to do with the bolts.
    Arizona, USA
    Re: Bolt from top down?
    Interesting idea, but the bolt is part of a sort of ball-and-socket joint that mounts and aims the lights. It's all sheet metal, so there is really nothing to tap into to mount the bolt in reverse (i.e., into the light).
    West Salem, OH
    Nice job on the lights! I think Dave had a great idea with the acorn nuts, I would add some blue loctite when installing them just for peace of mind. I love the brackets, and will shamelessly copy them to add a set of lights to my Roadster.
    Gale Smith
    2009 Versys
    1999 R1100RT
    Arizona, USA
    Eagle Eye lights web site
    Forgot to include the web site and manufacturer info for Eagle Eye Lights:
    Eagle Eye lights web site:
    http://www.eagleeyelights.com/
    Nice product catalog at the site, including a new 9-inch true-HID light. The Bonneville Salt Flats might be the only place on Earth you could legally use that light :-) . They also have a new self-contained 6" round HID light, nothing external required -- very nice, though it might be a bit much for a motorcycle.
    Eagle Eye lights are made by:
    JF Manufacturing Corp.
    18430 E. San Jose Ave., #B
    City of Industry, Calif. 91748
    626/965-3266
    Fax: 626/965-4080
    On the Road
    Aug 2003
    Idaho Panhandle
    Eagle Eye Lights
    Where do you buy these things? I can't find any prices on their website.
    Arizona, USA
    Re: Eagle Eye Lights
    The manufacturer doesn't sell direct. Do a Google search for "Eagle Eye lights" and you'll find a bunch of places that sell them.
    The model I have is the 1515HCC (5-inch, 100-watt, chrome housing). The 1515SSC is the same thing but with a stainless steel housing, about $10 more per light. They have a bunch of other models too, smaller and larger than the ones I have.
    State of Confusion
    Lightbulb Unistruct fixes everything
    So while cleaning/pining over the RT in the garage I saw the high tech mounting bracket I made for the weedwacker to hang out of the way. It is Unistrut(R) and uses a U Bolt to crandle the shaft of the wacker. Other brands also exist, such as ULine... No endorsement, I use "Unistrut" the way some people use Kleenex for tissues.
    (For those of you not familiar with Unistrut, erector set on steriods.)
    So I started thinking, could one of those be a "cleaner" mount as it would just go around the turn signal stalk and then have a mounting plate below it. I was thinking about 0.5" depth channel with a Spring Nut to mount the Eagle Eye into.
    Make sense?
    -=Brad
    Arizona, USA
    Re: Unistruct fixes everything
    Make sense?
    I'm familiar with UniStruts (have used them to make a quick-detach light mount for a couple of four-wheel vehicles), but I'm not clear how you're planning to use them. Seems you'd end up with something similar in appearance to the existing angle brackets, more easily removable at the expense of being more complex. Either that, or I'm misunderstanding what you have in mind.
    State of Confusion
    Re: Re: Unistruct fixes everything
    It is definitely more complex. The complexity would allow for no visible nuts. Below is a cross section. Black is the turn signal stalk, Blue is the U-Bolt, Green is the Bolt from the light, and Red is the short channel. All of the nuts would be in the channel. That is the only advantge, that plus you would not have to remove the turn signals.
    Just a suggestion. I am not sure of the clearance when turning though.
    -=Brad
