Results 1 to 3 of 3
Thread: CLC cylinder lock replacment on side case
    Registered User nplenzick's Avatar
    Dec 2003
    Warrington, Pa.
    I'm getting ready to replace the right outer side case that I damaged on my CLC. I'm wondering if anyone knows how to get the old lock cly. out of the damaged case and install it in the new one. I assume that you have to take the inside panal off but I can't figure how to do it. Four screws on the inside and two underneath the handle where removed and I still can't get the inside panel off. Any ideas?
    Focused kbasa's Avatar
    I haven't looked at a CLC case, but if they're anything like the system cases, there's a place on the inside of the bag to stick a paper clip in and pop the lock out. You need to have the key in it to do it.
    The IBMWR website (www.ibmwr.org) has a description of how to do it in their tech pages.
    Dave Swider
    Marin County, CA
    Dec 2003
    Warrington, Pa.
    Thanks for the info but the clc cases are not like that. There is no access hole. I still believe the inside panel has to come off to get to the lock.
