Results 1 to 9 of 9
Thread: Zumo 550 Mount
    Registered User easy's Avatar
    Feb 2005
    Texas Hill Country
    Zumo 550 Mount
    I went to the hardware store and got a u bolt that had threads about 1/2 inch longer and mounted it on the right handlebar. I ran the wiring directly to the battery. It is very visible, doesn't block vision of instruments and I did not need to drill any holes in the dash. It works great.
    Easy
    Registered User velocitas's Avatar
    Jul 2003
    MA
    Wiring to battery
    Easy,
    I am able to mount the Zumo fine and also want to wire directly to the battery.
    The wire ends are very fine (not sure of gauge) . How did you do this -bend the wires and double them up and then solder to a ring style connector?
    Doug
    Harrington
    Quote Originally Posted by Velocitas View Post
    Easy,
    Doug
    I had my dealer install a Centech fuse block. The fuse block is turned off automatically after the key goes off. I landed my Zumo leads to the fuse block. It now goes off approx. 30 seconds after the key goes off. Now I can't drain my battery down if I forget to turn off an accessory.
    I mounted my Zumo using a replacement handlebar bolt. Granted that I have a GS, but I think there is a replacement bolt that specifically fits the RT (chack the touratech site). I wired it in with a relay so that the power would shut off when I turn off the ignition; this works well with the zumo since the user can elect to run off the GPS battery after they turn off the bike.
    The mount and the wiring are documented here:
    http://forums.bmwmoa.org/showpost.ph...4&postcount=10
    Paul
    LINK: '07 Cross Country Tour!
    LINK: Support the Dana-Farber Cancer Institute
    those who mind don't matter and those who matter don't mind
    Feb 2005
    Texas Hill Country
    Wiring to battery
    At the electrical section of the hardware store, I got some electrical connectors for the wires with eyelets just big enough to connect directly to the battery. I crimped the other end of the connectors to the wires with a crimping tool. I didn't use any solder. It has a built in fuse so I installed it directly to the battery. Now it can operate while the bike is turned off.
    Easy
    Jul 2003
    MA
    Thanks for the different inputs.
    I am wiring directly to battery as I can still turn off as needed and will take the Zumo off the bike most of the time.
    As a F650 owner I do not want to add too many accessories that draw extra power.
    Here is link I got info on:
    http://razorbiker.com/zumo/viewtopic.php?t=95
    Here was an opinion in the topic (Not mine- use your own judgement)
    that helped me make up my mind.
    After reading the posts here, I decided to run a few tests to find out the current draw in various situations. Here are the results:
    Draw will be posted in mA
    Unit in cradle and turned on - 213mA
    Unit in cradle and turned off (not charging)* - 001mA
    Empty cradle - 000mA
    As it seems, there is no draw on the bikes electrical system if nothing is in the cradle.
    With these results I decided to go to an "unswitched" (direct to battery) hookup. "
    Doug
    bored, bored ... dlowry's Avatar
    Dec 2005
    Snow Country, ON, Canada
    I dunno if the Zumo has the same mount pattern as the garmin marine units, but I found the marine bolt pattern to be the same as the BMW NAV mount for the RT. I ordered just the mount and it sits where the factory unit does. It's a bit more money than RAM mounts, etc, but it is VERY securely mounted and the installation looks very clean.
    Feb 2005
    grand forks, nd
    no accessory plug adaptor?
    lots of good info here; I just ordered a Zumo for my 06 1200RT; is there not an accessory plug on the unit that I can use( obviously with my BMW adaptor), or is there another reason to hard wire to the battery or a relay? thanks...wj
    Mudbug
    It is not necessary to wire to a relay. You can wire directly to the battery or get a compatible fitting to the BMW adapter plug. Your choice.
    If you wire it through the ignition switch, the CAN buss will wait approx 30 seconds then cut the power to the zumo. When the zumo senses the external power has been cut, for what ever reason, it will notify you via a screen and ask if you wish to continue on the zumo's internal battery (yes or no).
