Results 1 to 15 of 27
Thread: Something Very Different
    Rally Rat PAULBACH's Avatar
    Dec 2005
    Has anyone ever rode one of these? Front wheel drive! Found the picture of this bike for the Big GIG thread.
    Thanks Greg. I resized and renamed. That did it
    Boise, ID
    Quote Originally Posted by PAULBACH View Post
    Has anyone ever rode one of these? Front wheel drive! Found the picture of this bike for the Big GIG thread. CAnnot upload same file twice so I have provided a link. Maybe the mod can work some magic.
    Click here.
    Just save the picture under a different name and you'll be able to upload it.
    Greg Feeler
    2017 Rally Chair & Ambassador
    OldAndBusted
    that's awesome. radial? who needs transmissions anyway.
    Dec 2005
    Old ride!
    1920's technology! The engine appears to be inside the spokes.
    Still Wondering mika's Avatar
    Aug 2004
    Fly Over Land
    Megola Motorcycles of Germany
    European Motorcycle Universe site
    Megola ΤΗτ Wikipedia
    Here is one with a bladder for a gas tank.
    Pass the mustard and UP THE REVOLUTION!
    St. Paul Pioneer Press , Minneapolis Star Tribune
    RandallIsland
    The first thing that comes to mind is how that might be such the trick for a hill climb.
    CTHalk
    Fully faired
    I know a guy with a fully faired machine, a megola or similar. It is wild looking, Buck Rogers comes to mind. He says only a few were built streamlined. H.
    Dec 2005
    Follow the link
    M1KA provides a Wikepedia link. An interesting read. One very interesting sentence from Wikepedia:
    The crankshaft was the front axle, which remained stationary while the cylinders rotated with the wheel.
    Am I missing something? How does the axle remain stationary? Would not the axle have to rotate for the bike to go forward?
    Another link for this interesting design concept.
    Oct 2003
    Not at all. It was a common design for WWI aircraft. Planes like the Sopwith Camel and such had a radial engine with its crank bolted to the airframe and the crankcase bolted to the prop. The idea was that the spinning crankcase would get more air cooling. Also, most of the engine could be covered for better aerodynamics, and yet all of the cylinders would see some cooling.
    When the motor runs, something has to spin. It doesn't have to be the crankshaft...
    http://darryl.crafty-fox.com
    Dec 2005
    Thank you! Some very interesting engineering going on. I wonder if any other motorcycles featured front wheel drive?
    Oct 2003
    I don't know of another front wheel drive like the Megola. But here's a Sachs rear wheel drive bike from the 1960s...
    Aug 2004
    Fly Over Land
    Here is a link to keveney.com and the explination of the Gnome engine, one version of a rotary engine. This may help you understand the concept a little better.
    Instead of the crankshaft spinning inside the cranckcase, the crankcase and everything else attached to it spins around the "crankshaft", or in the case of the Megola, around the stationary axel.
    Focused kbasa's Avatar
    I saw that bike at the Art of the Motorcycle.
    It's pretty strange, that's for sure, but not the strangest bike I saw there. I think that award goes to the Bohmerlander (or however you spell it).
    Dave Swider
    Marin County, CA
    My head just exploded.
    BUBBAZANETTI
    to answer paul's question;
    the Rokon Trail Blazer was actually a two wheel drive motorcycle, you could store fuel or water in the tires and when they were empty it would float:
    one thing i never understood about the megola or other machines with free spinning cylinders, how do the carbs or injectors get a steady supply of fuel, the only thing i could envision was a supply hose, that led directly to the crank that would fill a void in the spinning crank and allow the fuel to be fed up the cylinders and to the carbs using centrifugal force. any radial mechanics in the house??? i'm pretty sure the spinning engine was a rarity in the aviation world and wasn't commonly used after WWI
    edit: upon blowing up the picture above it would seem the carb is actually located in the hub. man those little straight pipes must have been LOUD
