Results 1 to 6 of 6
Thread: adding heated grip kit
    Bcpilot
    Question adding heated grip kit
    I have a 2001 F650GS and want to install the BMW heated grips kit.
    Has anyone done this? Want to know if its user-do-able. Thanks.
    Lifetime Member Ridealot's Avatar
    Aug 2004
    Salem Or.
    That all depends on the users mechanical abilities. To get a good idea of whats involved check out the Chain Gangs Technical Faqs page.
    Here is a head start for you http://faq.f650.com/FAQs/HotGripsIns...Q.htm#HotGrips
    If you look around the Chain Gang site you will find more information about your bike than you can possible read.
    Tom
    Salem Or.
    '93 K1100LT w/Bushtec
    '09 F650GS '15 Ducati Multistrada
    On the Road greggnj's Avatar
    Aug 2005
    Whitehouse Station, NJ
    I'm no motorcycle mechanic....
    ...but I installed the kit on my '03 F650. The tricky part is getting the heated throttle/grip wire in there without twisting or pinching it. You have to make sure when you slide the throttle onto the bar that the wire is in the correct position in relation to the cutout on the bar end, otherwise when you twist the throttle it will cut the wire-way down inside the grip where you can't fix it.
    Ask me how I know
    Even though I had to buy a new throttle for around $60, I'm sure I would have paid alot more for labor to have it done at the shop.
    Urbana, IL
    Quote Originally Posted by greggnj
    Ask me how I know
    BMW's flat rate for that job is 1.42 hours.
    My other bike is a BMW.
    Dec 2005
    I put heated grips on the '97 I used to own. I was able to but a pair of 'Hot Grips' brand that fit fine. They were around $50, which has got to be less than the BMW set. Installation was a bit rough. I would suggest doing it in a warm area so that the rubber and plastic can expand easily. Chain gang had some good tips as I remember.
    Simple. Fast. Paid for. rnr's Avatar
    Aug 2005
    Mid-Michigan
    doable
    just put some aftermarkets from aerostich on my R80RT, using a used BMW rocker switch from BMW of Grand Rapids to keep things tidy.
    Worked out fine, cheaper than BMW grips.
    Simple tools and basic mechanical competence necessary.
    For my next two bikes, I'm going with the www.dual-star.com unit.
    It's the 2.0 version of the kit that 'stich sells.
    ymmv
    (your millivolts may vary)
