Results 1 to 6 of 6
Thread: hard cases
    Jul 2003
    Leavenworth, KS
    Question hard cases
    I recently bought a 1988 K75S. Great motorcycle. I have a line on a pair of used hard cases for it, but I don't know for sure if they will fit my machine. They came off of a K-100. The photographs show the protrusion at the bottom front of each case that appears to fit into the mounting hole directly in front of the passenger footpeg. Can anyone say for certain that these cases will fit my K-75S? My motorcycle already has the hard plastic mounting rails. I just don't know enough about the cases themselves to spend the money through the mail. Is there a part number somewhere on the cases that will pin them down? Help!
    Focused kbasa's Avatar
    If I'm not mistaken, Kbike bags are Kbike bags for the first gen Kbikes.
    Dave Swider
    Marin County, CA
    Have bike, will travel lancew's Avatar
    Central VA
    Early K-bike bags are really tough to find for any kind of reasonable price- I tried for 3 years and never found any. If I were you I would snap them up- even if they don't fit I would bet that you can turn them around without losing any money besides maybe shipping costs.
    #92115 - '01 R1150GS
    Why don't they make a Nerf Martini Glass?
    Registered User k100lt's Avatar
    So. Calif.
    There is a lockable latch at the forward bottom part of each case. It locks into the hole on the plastic side rail. I have an 1989 k100lt. I believe that the side cases were the same. You might check with Bob's BMW in Maryland. They carry side cases for all years of 'K' bikes. There catalog is also a good source to have for p/n's..
    Good luck...Dave
    David
    1989 K100LT
    Registered User kioolt's Avatar
    Maryland
    Yes they will fit
    The early K-bikes (K75, K100, K1100, all varieties) will all use the same cases. There were two styles of cases for these bikes. Both styles fit the same mounting hardware.
    2004 R1150RT 171,200 miles , 1991 K100LT 128,700 miles, 1982 R100RT 106,900 miles
    Total 406,800 BMW miles
    AMA,BMWRA,BMWMOA
    The cheapest thing on a BMW is the nut that connects the handlebars to the seat.
    eric2
    Re: Yes they will fit
    ackchooly, there are 3 variations:
    first flat latches with tiny, toy like keys
    second normal latches pointing inward
    third normal latches pointing outward
    The last two can be keyed the same as the ignition
    HTH!
