jerry said:get a little off track here did we?
rider1150RT said:I know that the EVO system is complicated but laws of physics still apply. It should be possible to change the fluid this way.
pmdave said:Unfortunately, BMW has apparently dropped the GS "Sport" from the lineup. The standard R1150R may still be available. But the plan appears to be to have Integrated ABS on all bikes.
---Visian said:Rider -- complicated indeed. So complicated that if you only bleed the brakes, you don't bleed the servo-proportional-abs-linked-dowhatzy-in-the-middle-of-the-whole-works and you're hosed!
Trust me. This is a dealer job. At least until your warranty expires.
Ian
rider1150RT said:All right ,I guess the dealer wins on this front.
CABNFVR said:---
Just a few comments on the original thread topic:
EVO is the new 320 mm diameter rotor and calipers. EVO has nothing to do with Integral, which is what we're talking about here. The K12RS has partial Integral with EVO, while the R and KLT have Integral EVO (rear activates front. Glad I don't have that.)
---Visian said:1) Well... maybe we're talking semantics here, but I can tell you that when I apply the rear brakes on my 2002 K12RS, the fronts come on. .....
2) ps => I looked at the procedure that "you" over at i-bmw.com are doing... there is no way that I am going to go through that much kludge factor... what a mess! ......
3) And you're right... going back and forth between bikes that have the new brakes and the old brakes is a major PITA.
CABNFVR said:---
1) Your front brake does not come on with your rear pedal. Nope, not on an RS.
2) What kludge? It's just a normal brake bleed, unless you introduce air, then you're (oops, can't say that over here).
3) Yep, huge difference in feel between our Ducati and the RS. Both good brakes, but way different.
"One outa three ain't bad"
Tim
