Results 1 to 15 of 16
Thread: What type of Headlight bulb do you recommend?
Hybrid View
    Registered User boxerkuh's Avatar
    Carolina's
    Question What type of Headlight bulb do you recommend?
    Here is the deal... my headlight bulb blew up for the second time this year.....
    In May my head light low beam blew up and I replaced it with a high intensity "blue" bulb. I love the light it gives, but the longevity is very poor. I even made sure that I used the "high" beam and the "low" beam were used equally. Last night the high beam blew... Years ago I had the same problem with my oilhead and I swore I only use the cheap one's, as they last longer...
    So, what have you found out to be the best for good lighting, good price and good life, which one would you recommend?
    Here are some limitations to lighting... I don't run auxilary lights and don't plan on installing any, so the light source is the "headlight." I ride daily, it is my mode of transportation and I average about 15K per year... but 3 months is totally unacceptable... Any feedback would be greatly appreciated, as I will change the bulb this weekend... Thanks for your opinion...
    Keep the rubber side down!!
    1986 R 80 RS
    1992 R 100 R
    BMW MOA Life member; Ironbutt Member; Airhead Member
    Registered User burnszilla's Avatar
    May 2004
    Redwood City, CA
    Osram Silverstars from the UK. Don Eilenberger recommends them. I've been using them and they last longer and are much brighter.
    http://www.powerbulbs.co.uk/
    Stephen Burns - 2007 R1200GS
    BMW MOA Lifetime Member
    www.burnsmoto.com GS911 WIFI BMW Motorcycle Diagnostic Tool
    Registered User Rod Sheridan's Avatar
    Oct 2005
    Toronto Ontario
    Hi, I use the H4 Sylvania Silverstar lamp # H4ST in my 76 R90/6.
    The rated lamp life is 150 hours low beam, 50 hours high beam, at rated voltage (14.0VDC). Note that running at 14.5VDC the lamp life factor falls to aproximately 65%.
    Regards, Rod.
    Rally Rat paulsibek's Avatar
    Apr 2004
    near Los Angeles
    I agree
    Quote Originally Posted by Burnszilla
    These are terrific.
    Whatever you choose...
    +1 for www.powerbulbs.co.uk
    After reading a similar thread awhile back, and because my Sylvania SilverStar H4 high-beam bit the dust after 4months ~4500mi, I bought a pair of Euro-spec Phillips VisionPlus from Powerbulbs. They look slightly brighter/cleaner than the Sylvanias, and we'll see if they last. But what I am really impressed with is the price and service from Powerbulbs. A pair of the Vis+ to my door in eight days, for just over 35bux.
    The Sylvanias are $20 apiece at AdvanceAuto....+ the Gov's share.
    JMagda
    Deep in the OH wasteland...
    04 R1150r
    Smile
    Phillips Vision Plus purchased from www.casporttouring.com.
    No affiliation, usual disclaimer, yada, yada.
    The Vision Plus bulb is superior in light and longevity to the Sylvania (U.S. version) Silverstar because of the latter's slight blue tint. The Osram (European) Siverstar is comparable to the Philips Vision Plus.
    Frank G.
    Hattiesburg, Mississippi
    2004 R1150RT
    Carolina's
    Thumbs up
    Thank you very much for your feedback. I just odered a Vision Plus bulb from casporttouring. I did some research on the information that you gave me and also found out that "car" bulbs don't work so well, because of the added vibration from a motorcycle. I did not know about the longevity of the high beam and low beam. Awesome what you can find out if you ask a question...
    We are a great bunch of folks... Thanks for all your help...
    1986 R 80 RS
    1992 R 100 R
    STAN
    Question
    After reading this thread I ordered the Osram from the UK. No freight, good deal. Figured I'd replace the low beam bulbs now and save the old for emergency. R1200RT. What an ordeal. Son and I over an hour. No room for hands, drew blood before I was done. They also sent the two 5watt side bulbs for no charge, even though I did not order them. Those were easy enough to change. Seems like German engineers planned on Japanese hands. Did I miss something obvious, or am I just clumsy?
    How cold was it? shoeman's Avatar
    Jun 2004
    Lake Wabaunsee, Kansas
    While the selection of a bulb is important, remember the ability of the wiring harness to deliver the power required to support the bulb. Somewhere on Adventure Rider website ( about a year or two ago) there was an excellent test performed on various bulbs with various relays and harnesses. the results were clear on what was required. A search of the advrider site would probably turn it up.
    Jim Johnson, OP Kansas
    Marcus Aurelius: "The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane."
