Results 1 to 8 of 8
Thread: Using oil
    On the Road Mike Barnett's Avatar
    Sep 2003
    Springdale Arkansas
    Using oil
    Is a 94 K11LT with 30K miles supposed to be using a quart of oil every 3000 miles.
    Registered User PHMARVIN's Avatar
    Oct 2003
    El Paso, TX
    Hi, Mike,
    I don't know if it's "normal" or not, but my '96 K1100LT with 111k miles does use and has used a quart every 3k to 4k miles, and has done so since I bought it with 14299 miles on it. I used Castrol GTX 20w50 for the first 30k miles or so, and Mobil 1 15w50 synthetic ever since. I add oil as necessary (when I can't see any in the window) and change it and filter yearly or at 10k miles, whichever comes first.
    Ride Safe,
    Phil Marvin - El Paso, TX
    '94 K75A/3
    '95 K75RTP
    Sep 2003
    Springdale Arkansas
    Thanks Phil for the info. I heard this from another K LT owner but I didn't believe it. Maybe it is normal. Does your fuel pump squeel real loud when you ride 150 miles or so. Mine does. It's embarrasing when a Harley pulls up beside you at a red light and he can hear your bike squeeling over his bike. Mike
    Has the GS-Lust The_Veg's Avatar
    Sep 2003
    Atlanta 'burbs
    I know for most cars (and the K engine is basically a car engine) a quart every 1000 miles is considered the maximum allowable consumption, at least traditionally. So you're probably okay, although I can certainly understand wishing it used less.
    What's that noise...? basketcase's Avatar
    Alabama
    Three K models:
    - K100 never used a drop.
    - K75 used about a half quart in 3,000 miles.
    - K1100 seems on track for around a half- quart per 1,000 or so.
    Aggravating.
    '98 BMW Z3 Roadster, '00 R1100RT
    If you insist on exercising a right to burn our flag, first be so kind as to wrap yourself in it and then douse yourself with gasoline just before you strike the match.
    The K1100 series is known for burning more oil than the early K bikes. The K75 and K100 usually burn very little oil betwen changes.
    Frank G.
    Hattiesburg, Mississippi
    2004 R1150RT
    Sep 2003
    Springdale Arkansas
    Rick your dead on. I've used 2 quarts in about 4K miles. I can't believe that's exceptable, but I guess it is. Mike
    Registered User Antman's Avatar
    Nov 2003
    Florida
    using oil
    Mike,
    When I first bought my 1995 K11 it had 4,000 miles on it and was using about the same as yours is. It may be helpful to hear my bike now has 56,000 miles and the consumption is 100CC's per 1,000 miles.
    The only problem is that on a long trip I have to take oil along because I will not use SJ auto oil in a BMW.
    My former K100RS had 161,000 miles and it never used a drop; even on a extended high speed run of 41 minutes at very high speeds.
