Results 16 to 30 of 35
Thread: Glasses / Contacts
    USERNAME
    bubbagazoo - look into waveguide lasik. that's what i had done. my #1 concern was spherical abberrations causing night vision issues. i learned something VERY interesting, and that was that i had artifacts in my night vision with contacts and with glasses! imagine my surprise! i had both starbursts and halos PRIOR to the surgery.
    i had the surgery, and the artifacts have lessened considerably. my night vision rocks now, and it's one of the things that makes me happy that i had it done. it's a little different for everyone, but the waveguide has such a small ablation area that they can really clean up a lot of the defects you might currently have.
    Rally Rat EastTNBeemer's Avatar
    Aug 2004
    ...the hills of Tennessee
    Quote Originally Posted by wuli959
    pretty interesting. are you near or far sighted? what was your original vision 20/?
    I am nearsighted. My right eye was terrible- somewhere around 20/150. The left was better, but not by much. I'm very happy with the results.
    RK Ryder
    London, Ontario
    Glasses work well
    I am not a candidate for corrective surgery. Disposable contacts with different prescriptions for each eye worked well for me. However, since I'd usually only wear a pair once or twice (didn't feel the need for them unless I had a photo shoot), I bought the non-throwable ones this time around. They work well in the daytime but once the light gets dim, my vision is equivalent to being impaired. Consequently with the current set of contacts, I do not wear them while riding. Riding with glasses is no problem, especially since I have added an eye glass holder to the handle of the left case to facilitate a place to set the glasses when putting on or removing the FFH. A bungee net while touring is even an easier location to snag the glasses onto while changing the helmet. I envy those with the corrective surgery or those who successfully wear contacts.
    Paul
    Knights of the Roundel #333
    jeneralist
    Quote Originally Posted by FredRydr
    I don't understand. How do your lenses wrap around the periphery of your vison? I've never seen such a thing with glasses.
    Fred
    I've worn glasses for almost thirty years, and I've just figured this one out. Are you familiar with the "wrap-around" style of sunglasses? Well, some of them can take a prescription lens, as long as the prescription isn't too severe. I need two diopters of correction for nearsightedness; I had tried contacts, but my eyes always felt tired, hot, and dusty when I used them to ride. Then I got the wrap "sunglasses" -- one pair with clear lenses, and one pair to really be sunglasses. Now I've got correction in my peripheral vision! It's a wonderful thing.
    chfite
    I don't understand the comment about limited peripheral vision. I see the same peripherally with or without glasses. Our eyes can focus only in the center of the visual field. This is why we look where we want to see clearly, and why the center of focus of corrective lenses is in the center of the visual field. We can see clearly only to about thirty degrees either side of center without turning our heads.
    It is the sides of my helmet that block some of the visual field, limiting my peripheral vision. To compensate for this, I turn my head.
    Danger: Keep Back 500 Ft FredRydr's Avatar
    Jul 2005
    central Pennsylvania, USA
    Quote Originally Posted by jeneralist
    ...the "wrap-around" style of sunglasses? Well, some of them can take a prescription lens, as long as the prescription isn't too severe....
    Thanks for the heads up about this. I can't envision them (pun intended), but with the slight correction for my one eye, this sounds feasible for nighttime riding/driving. Do you have a brand or model number for your prescription wrap-around lenses?
    Quote Originally Posted by chfite
    I agree. That is exactly the problem with glasses (except apparently with what jeneralist has found, above). I had glasses since 1959, and glasses and contacts since 1968. When preparing for Lasik, I had to forgo my contacts for two months, requiring me to use my glasses full-time. The loss of sharp peripheral vison while riding and driving was a real bummer.
    Fred
    I've also worn glasses my whole life. I never noticed the loss of periferal vision before. You're right. If I tweek my eyeballs to the side and don't look thru the corrective lens the world gets blurry. I guess I've always just turned my head to compensate.
    robert
    USERNAME
    you get used to what you see all the time. so if you wear glasses all the time, you think your peripheral vision is fine. if you have a strong prescription, it's not. it's all just blurry blobs off to the sides. typically, i have not ever really been able to tell that my vision was lousy until i was presented with a better alternative. when i had glasses in my 20s, i thought i could see fine. i went to the optometrist, and found out that my eyes had degraded a bit. when i put on the new glasses, i was AMAZED. i simply couldnt tell before that my vision wasn't as good, my mind had adjusted to the way things were. if my forward vision had degraded, then my peripheral vision certainly had. it makes me nervous to think that my peripheral vision is not at maximum on the motorcycle.
    little tiny movements in the corner of your eye (periphery) are the things that can be the difference between life and death on a bike. if you're wearing glasses, and have to turn your head as a result, that means you arent facing the direction you are going. that means that you need to turn your head BACK to the front to reassess hazards in front of you.
    just sitting here at my desk, i did an experiment - i sat with my desk lamp over to my right at about 45 degrees. i can flick my eyes, focus on it, and then flick them back straight ahead, in less than 300 milliseconds. it takes me about 600 to turn my head, look at the lamp, and then turn it back forward and refocus. (i'm trying really hard too, i'd likely be lazier/slower on the bike, and i'd have a helmet/wind forces to contend with.)
    at 70 mph i cover 102 ft/second. so if i take my eyes off the road for 600 milliseconds, i cover 61 feet. my bike is 8 feet long, so i cover almost 8 bike lengths not looking where i am going! if i take my eyes off the front for 300 milliseconds, obviosuly it's half the distance, or around 30 feet.
    i think it's more likely that i would be turning my head in city traffic, so let's say i'm going 40mph in that scenario. that's 58 feet/sec, so i'd cover 35 feet in 600 milliseconds and ~17.5 feet in 300 milliseconds. still pretty crazy, but i'll take the extra 17 feet for braking/swerving.
    give me contacts/lasik on the bike, anytime, anywhere. it gives me a slightly larger safety margin, and my mentality when riding is to do everything i can to decrease the probability of wreck/injury. (short of not riding, that'd be NUTS! )
    Retired and proud of it MOTORMAN's Avatar
    Feb 2005
    Full time RV'er, wherever I park.
    If you can't see to the side perhaps it's not the fault of the specs as it is the choice of what frames and lenses to buy. If you go with the small granny style lenses heck yeah you will have reduced clear peripheral vision. I use "aviator" style frames with medium lenses and have great peripheral vision and have tested it. As a pilot I had a physical every 2 years and a peripheral check was part of it. No differnce in the test for me with or without glasses. I still had the range of view either way.
    Frankly, if your head isn't on a swivel anyhow you shouldn't be riding. Don't depend on seeing something from the corner of your eye. SCAN the world around you.
    Slowpoke & Proud of It! BRADFORDBENN's Avatar
    State of Confusion
    My right eye is so bad that I see noticeably better to the periphery with the contacts that is why I ride wearing the contacts. Just to give you an idea, un corrected it is 20/450. It means what I can see at 20 feet a "typical" person can see at 450 feet.
    -=Brad
    It isn't what you ride, it is if you ride
  11. #26
    jeneralist
    You're right; strictly speaking, the glasses don't give me improved peripheral vision. What I had been annoyed by was the need to turn my head to see something on my side, rather than merely moving my eyes.
    If you wear glasses now, try this: with your glasses on, look waaaaay over to the right. Odds are, there's a line across the middle of your visual field where your glasses frame is. To one side of that line, your vision is corrected; to the other side, it's uncorrected and blurry.
    The wrap-around glasses have a shape that moves that line much closer to my temples. I can't move my eyes far enough to one side or the other to notice that line anymore.
    Fred
    My frames are by Brooks Brothers model BB 332-S. I went to one of the big eyeglass chains' -- Lenscrafters? Pearl? -- sunglasses departments. I brought my helmet with me, so I could make sure that the glasses would fit under my fullface (not flip-up) helmet. And I tried on about a dozen pairs, pushing them to my nose and then looking all the way to one side without turning my head.
    Oh -- and don't make a mistake that I made. Don't get polarized lenses. My sunglasses give my windshield a rainbow sheen....
  12. #27
    Nov 2005
    Calgary, Alberta
    glasses/contacts
    Dave:
    This thread has been quiet for a while, and there hasn't been a response to your query about members' experiences with multi-focal contacts. I would suggest that you try to get an ophthalmologist to refer you to a good optometrist in your area, and ask them what their patients' experiences have been with them; it's probably variable. If you don't know an ophthalmologist, you could ask your family doc, or possibly, an optician, to refer you. Also, there are ophthalmologists who include contact lens work as part of their practices, and you could consult with them. Also, ask your professional for their opinion on the new "Focus" lens by CIBA Vision.
    As an attorney, your near vision will be a major priority for you.
    Good luck.
    Rinty
  13. #28
    Jul 2005
    Here is how I dealt with needing a lens for reading the GPS after my Lasik. I bought these Optx 20/20 HydroTac lenses (now on sale - two pair for $20, less than a cheap pair of readers) to apply to the inside surface of my faceshield. I apply one at the bottom center-left of my faceshield, where the GPS screen falls in my field of view. Make sure you apply the correct side of the lens to the faceshield; it is counterintuitive and the instruction is not clear. Note that this is not a permanant application, and the lens is easily removeable. I carry the extra three lenses in a little container as backup.
    Fred
  14. #29
    JCS97RT
    I got the multi-focal soft lenses about four months ago. They have been far superior to the bifocal glasses or the single vision gas perms along with reading glasses. You give up just a little in both distance vision and close up from the contact/reading glasses combo (it is a compromise) but it is well worth it to need reading glasses only in extreme conditions (Very low light or very small print). I throw a cheap pair of readers in my pocket and rarely ever pull them out. I have been very pleased with the vision and comfort along with the added convenience.
  15. #30
    Oct 2005
    Whitefish Bay, WI, 3mi N Milwaukee
    wavy peripheral vison with curved glasses/"wraparounds"
    If you cannot tolerate contacts, look into Zeiss curved sunglasses. Curved glasses with no wavy images. They came into the market about 5 years ago. An optomitrist who specializes is sporting sun glasses (fishing, shooting, flying, golfing, etc.) told me about them.
    They are EXPENSIVE! ...and mostly in big cities. In 2000-01, a pair costs about $2,200.
    anybody up for a ride to the Big Apple for flawless sunglasses?
    "What is beautiful is simple, and what is simple always works"....Kalashnikov, inventor of the AK-47.
    Current bike: 2015 Yamaha TW 200, modified for road/street use with tire, sprocket upgrades. "Center yourself in the vertizontal. Ride a motorcycle...namaste' "
