Results 1 to 5 of 5
Thread: Good gear, good stuff!
    Oct 2005
    Whitefish Bay, WI, 3mi N Milwaukee
    In the last two weeks I have added/bought/modified the following for my '02 R1150R), and I am very pleased with the results:
    BMW Summer Pants with armour & zipp-off bottoms. The feel great. I actually found a pr in Illinois that fit me. BMW cuts roomier cloths compared to Revit, and others. When you have a body built by pasta and Haaagen Daaz rather than soloflex, this is important.
    Foot peg lowering kits and modified extended shift lever from Suburban Machinery. Good Stuff. Only had to modify one screw (cut about a quarter of an inch off) with a dremel in shift linkage for a perfect fit.
    Bar backs-very nice. I actually feel like I am now on the bike rather than over it.
    "What is beautiful is simple, and what is simple always works"....Kalashnikov, inventor of the AK-47.
    Current bike: 2015 Yamaha TW 200, modified for road/street use with tire, sprocket upgrades. "Center yourself in the vertizontal. Ride a motorcycle...namaste' "
    Registered User Kenn45's Avatar
    Aug 2003
    Edwardsville, IL
    I have a set of the Suburban Machinery bar backs. I put them on my '04 RT. When I turned the bars in either direction, the forks pulled against the wiring harness. I cut the zip ties and rerouted the wires to the sides, and that problem was solved. However, when I turned the bars all the way to the left, the forks pulled against the front brake line. At that point I took them back off. Did you have that problem? Did you do anything about it (extend the brake line or something) or ignore it?
    Oct 2005
    bar backs
    I have not experienced any problems after I cut the plastic ties.
    Aug 2006
    Temecula, California
    Ignore it...
    Quote Originally Posted by Kenn45
    Of course proceed at your own risk...but I also noticed the Bar backs slightly pulled on the brake line. I chose to leave them on and haven't had any trouble...6K MILES LATER...
    kSMITH 57
    Oct 2005
    bar backs
    My bar-backs were from Moto-Techniques. I cut the plastic ties and all problems were solved. If I am not mistaken, there are two versions from Moto. One moves the bars back more than the other.
    Both the extended shift lever and peg lowering kits were from Suburban Machinery.
    Sorry for the confusion.
    Btw, I purchased everything from the "Flea Market".
