Results 1 to 13 of 13
Thread: Larger handgrips??
    Yeti
    Larger handgrips??
    Does anyone knwo of a good source for larger handgrips? The grips on my R1100RT are too small and cramp my hands.
    Thanks,
    Jul 2006
    Larger Handgrips
    Try the Sunline Grand Touring Grips
    You can find them at: http://www.casporttouring.com/store/...vc?Screen=SFNT
    Jul 2006
    Larger Handgrips
    Don't forget you will need to buy two pair for your Beemer....
    http://www.casporttouring.com/store/...Code=Hand-Cont
    Jul 2006
    Larger Handgrips
    I forgot to mention they carry a product called Grip Puppies that will install over your existing grips....
    Yeti
    Quote Originally Posted by azwoodman58
    Thanks for the reply! Why would I need two pairs?
    Jul 2006
    Larger Handgrips
    If you have heated grips then both bars are throttle diameter size.
    Aug 2005
    Thumbs up
    Another slip over solution are Jabco Grip Covers. I use these on my R11RT.
    www.foamtubing.com.
    No affiliation, usual disclaimer applies, yada, yada.
    Yeti
    Ah. No heated grips needed here in San Diego. Now cool grips . . .
    Grammarian no, Rider yes ISAMEMON's Avatar
    Jun 2006
    Kings Valley Oregon
    got and installed my grip puppies last night
    wow what a difference, well worth the $7
    Port Angeles WA
    You might seriously consider the Hunter Flat Bars--oval shaped bar ends that replace your current bar ends, throttle, and grips. Both heated and unheated are available.
    I have not tried these myself, but Brian Halton (owner/editor City Bike magazine) swears by them.
    info hunterflatbars.com or 415 786-6312
    pmdave
    aaront
    Sunline grand touring grips = cheap and good
    Plasterman tgf429's Avatar
    Aug 2006
    Tiffin, Iowa
    Size for R1150RT
    What size of grip puppies do I need for a R1150RT with heated grips
    Tom
    Registered User ALIENHITCHHIKER's Avatar
    Oct 2004
    Asheville, NC
    I've got probably 10k miles on a pair of Sunlines. They've ben comfortable for me - the stock grips were not. I also felt they were too narrow.
    Steve
    Current Hottie: '00 R1100RT
    Old Flames: FY K100RT, '80 XS850 with Vetter Quicksilver, '67 Bonnie, '66 Honda 90
