Getting ready for a trip to Idaho from North Dakota. Changed final drive oil and attempted to inspect and grease final drive splines and found the U joint rusted to the final drive input shaft. Trying to soak it overnight with Kroil penetrating fluid. Prying between the shaft and U joint didn't do the trick. Not feeling good about this. I guess my next move is to cut the gator off and try some heat on the U joint yoke. Being careful not to burn any seals. Any thoughts?
